josh blair
Can anyone help me? my massey ferguson 150. the hydraulics are screwed up eveytime i start it they go up, but not down. no matter what i do. NOTHING!
Not familiar with that tractor, but a general starting point is to clean or replace the hydraulic oil filter and change the hydraulic oil.
Does it go down if there is an implement on it? Can you make it go down by putting your weight on it? If so, it might be merely tight o rings in the internal cylinder and it might improve with use.
You might get more expert answers if you post this on the Fergueson forum.
Good luck,
KEH
If you only have pressure up and gravity down, loosen the line that lets the oil out of the down side of the cylinder and see if the hitch goes down. If it does, that would tell you that the spool in the valve is stuck not letting the oil out of the cylinder. If it doesn"t, then something is trapping the oil in the cylinder. Could be that the spool is stuck in the up position. rw
This has been dicussed in the Massey forum several times, including the 135, 165, and other models in the same family with the same issue. Go over there and do a search, or just ask over there. We've got a 165 and 285 ourself, but haven't had that issue so I can't adivse you how to fix it.
I think it can be done through the cover that the dipstick goes through however.
Donovan from Wisconsin
I was there only 13 years ago myself. Just be sure to watch what you're doing and eventually you'll be able to tackle many more projects that are more difficult than this.
Even when brand new, the 3pt. only had pressure up and gravity down. There are no external lines on the cylinder. Everything is internal. Check the archives on the Massey forum and/or ask on there as was already suggested. Dave
