hesston pt10
Doug246
On my Hesston pt10 I replace the pitman bearing with one ordered right form the dealer. The only problem is that its about 1/2inch wider than the old one so there is no room to reinstall the counter-weight that bolted on to the end of the shaft. I checked with the dealer and he searched all of the years of the pt-10 and couldn't find any different bearing for it and not one of them even listed the counter-weight as a part. Does anyone know if at some time Hesston decided that the counter-weight was no longer necessary and discontinued it?
Thanks for your help!
you have the wrong bearing try again the right one appears like it is wore out before you put it on it is a specail one. you need the counter weigth. gerald
thats part of the problem. The dealer doesn't show any other bearing other than what I got. All the listing for the pt 10 are the same
the was a change in design on those haybines and I know because I used to have 1 of each. Don"t know when they changed tho.
My manual shows a counterweight. I have a PT-7 and there is a difference in years. My manual is for PT7-20900 and up and PT10-22200 and up. On mine the reel drive is routed differently, so I think mine is the older model. You may have to get a serial # and have the dealer check again. I have run into that sort of thing on other makes as well.
Well I ran it for about 30 minutes without the counter weight and it seemed to run fine. But thats all i had left to cut for now. I'll use it more next week when I cut some more.
There are 2 types of pitmans on the PT-10. The ball and socket type and the U joint type. Which do you have? The pivot brackets are differant.
I ran my PT-10 without the counterweight for years. I never found it when it flew off.
