grandpa Love
Can't find your post about the cub magneto. I couldn't figure out what would be moving so I went to the barn to investigate. This is the only part that comes loose. 3 screws hold it in place. Hope this helps..... If yours is busted somehow, call me I have 3 good cores..
I have one cub that the slots on motor side are wallered out bad. Magneto tangs wouldn't sit correctly, but a distributor did... I also have 2 good distributor cores..... Let me know what you need. Your friend in Alabama
According to the parts book I found on line, it comes apart at the joint indicated by the arrow as well. It reads as 4 screws hold this joint. Either way it looks to me like he needs to remove it and open it up, at least part way, to repair it.
Your right and I have the mag off the tractor and the heads of the screws/bolts that hold that part tight are ground off so there is no slot for a screwdriver to fit in so I'll have to find new ones
Again you have no clue. Distributor is $150 plus then you need the adapter which is another $72 and then you need the drive parts so comes out to well over $300. Leave me alone unless you can give me good correct info and stop trolling me
