Hhydraulic lift problem
Roger Steele
I had posted about this problem a few weeks ago, but I am gone a lot. I'll try it again. 8N , I pulled both inspection covers with engine running there is an oil swirl. On the left (starter) side you can see what looks like a rocker box with two oblong cylinders? Ther kind of move up and down. To the outboard side is a bolt and hold down securing two valves? Can only see the top about nickle size. Through the right side cover there is 1/4 to 1/8 movement in the control. The lift arms do not move at all.
Thanks for your help
for an 8n, pull the right side cover with the dipstick.. when you pul the lift handle up, the bar hanging down from the top should move the control valve in the pump.. if the valve is stuck, the arm won't move. also.. if the cam pin is excessively wore, the bar won't move much.
try manually moving the bar and see what it does.
ps... some swirling in the oil is normal as there is a pto shaft driving the pump..
post back
soundguy
Roger, if you search this site for Hydraulic Lift, you will find a post on 3/21 by Dunk that gives a real nice diagrahm of how it should be working. Having an uderstanding of how it works can sometimes prevent having to tear into it.
The top of the pump should look the same on both sides. The left side should have a hold down bolt and a bracket that hold down the two valve chamber caps. If the left side does not have it like the right side it is probably somewhere down in the oil arond the pump or even in the middle of the pump. Looks like a pump pulling to me unless you can find the missing parts and put it back together while in the tractor.
Zane
