Good morning, two questions today.
1959 880 gas, was using the tractor to rake some hay for a couple hours or so. Finished up, parked the tractor, let it idle a bit and then shut her down. When all was quiet there was a hissing sound, appeared to be from the gas cap. Should the gas cap be vented? I've never heard(or noticed) that sound before.
The other question has to do with the generator, the belt is tight, but the dash light is on when the tractor is running. It seems like it doesn't charge the battery, but once running it supplies enough to keep it running. How do I check the generator, what should I look for?
