I puttered around working on the tractors for 4 hrs this am.. chased 1 leak and then went to work ont he pretzle-bowed steering draglink.
took about an hour of torch, copper maul, chissle and 2 pipe wrenches, not to mention some colorfull language to get the tie rod ends off the bent draglink, plus get the adjusting colalr off the draglink end near the tractor. I canabilized the 2 threaded ends with squee-zum clamps from the old draglink, and the welded in a thick walled metal tube. Have about 1" in and out adjustment on each side.. so should be good to go. Had jacked up the tractor and centered the wheel, then disconencte dthe arm, and determined the middle of the steering box so I had same amount of turnes each way, and then selded the arm up with the 'adjustment' od the ends set to 'middle' so I could fudge a couple inches either way if something wasn't quite right.
turned out perfect... or at least close enough!
I'm headed out to get some dinner after I feed the chix and the pigs!
soundguy
soundguy
