hopefully last question
s19438
put spin on adapter on 35. I am assuming the plate goes with the "bump" towards the filter ????
I guess sparex thought it was such an easy installation directions are/were not needed.
thanks again.
S,
Be very watchful with that filter if you are doing some rough area Bush cutting!!!!!!
It was a short time ago that a fellow installed one on his tractor, a stick was kicked up by the front wheel, it hit oil filter, busted it, but he saw it before all the oil ran out.
My old D14 AC had a spin on filter, but it was located high up on the side of the tractor.
I ran over a small brush pile once with my to35, there was a small tree stump in the brush pile, as my tractor came down the small stump went up through the opening in the frame bracket under the crankshaft pulley. The stump busted the pulley in a hundred pieces.
Just be careful.
about the "nastiest" work my machines do is plowing and discing the garden. thanks for the advice !
