Hour meter measurements
How are hours measured on tractors? I have heard that the newer models will count even with the key left on while older models only count at rated PTO. Any truth to this?
Looking for a newer tractor and have noticed that some of the newer ones(mid-90's) have higher than most of the older ones(late 80's).
The meter on my JD is electric, and runs as soon as the switch is turned on. The shaft driven meters had to have rotation, and I bet you're right about rated PTO speed.
But wait - they would surely work like the odometer on the older cars. They registered correctly no matter what the speedo registered. I think the shaft directly drove the odometer, and the speedo was driven by a magnet spinning in a cup, or vise versa.
Interesting question. Someone will enlighten us, no doubt.
Paul
If the tractor has an electric hour meter it typically registers one hour for every hour the engine runs, no matter what the speed.
If the hour meter is mechanical, it registers one hour for every hour the engine runs at rated speed, say 2100 RPM.
If the engine idles at 1/2 speed for one hour, in this case 1050 RPM, the mechanical meter will register 1/2 hour, as an example.
lATE MODEL ONES WILL NOT RUN WITH HJUST THE KEY ON. THEY (AT LEAST THE KUBOTAS0 ARE TRIGRED BY THE ENGINE OIL PREASURE. ENGINE HAS TO HAVE OIL PREASURE THEN THE HOUR METER GOES TO WORK. HOUR FOR HOUR REGARDLESS OF ENGINE SPEED. EARLIER ONES USED MECHANICAL SHAFT AND COUNTED ENGINE REVS WAS CALBRIATED TO COUNT ONE HOUR AT WHAT EVER THE PTO RATED SPEED WAS
My 1955 Oliver Super 55 diesel counts an hour @ 1600 RPM. That is PTO speed. A neighbor has a John Deere with an electric hour meter that runs an hour in real time with the key on, engine running or not running.
