I bought the 895 and am going through the fluid replacement process. Unlike the 395 with removable panels up front, under the hood, this seems to be an early 1991 or so model and the hood is all in one piece. I will have to string some ropes from my shed and work it up and out of the way to get at things.
I haven't found out how to drain the radiator and don't see a block drain on the engine to drain that. Really need to get new coolant fluids before the next freeze.
Other thing is, it has the XL cab and on the glass, visible from the front of the cab, is a diagram showing the fuse compliment but unlike the 395, there are no fuses available where the cover is over the battery. Where are they?. The battery on this one is below the left side step making it easy to access.
The full set of manuals I have address not only the 395 but all the way thorough the 895. Very comprehensive and the volumes are about 6" thick.....lots of pages to flip through trying to find what you want to view.
One problem I want fixed is the instrument panel. Currently the only things that illuminates are the hand brake energized or not and the oil pressure. If I can find the fuse panel maybe all I have is a blown fuse to get the tach and temp indicators to energize.
Really impressed with Case IH ruggedness. The 395 is what caused me to move away from my favorite Fords and go with something else. Big difference in the two brands in terms of built tough and longevity.
Replies appreciated.
