How do stack wagons work?
I have always put up hay with a thrower, but am considering switching to a stack wagon so I don't need as much help. They are not common here. How do they work? Are they fully automatic, or do you have to work the controls to load them? What are the smallest bales that will work with them? I sell all my hay, and smaller bales generally sell better. 50 lbs sells fine, but 70 not so well. Do some have self contained hydraulics are others not? Thanks for any advice,
Josh
We use a New Holland pull type bale wagon. Model 1033. It takes a little practice and PAY ATTENTION TO WHAT YOU ARE DOING. Get a manual and read it and go pile bales. Pay paticular attention to the lenght, make a tight bale and you will get better every load you pile. Look at roeerimp.com. They handle all types of wagons and have a demo to look at. Good luck.
Josh- A friend of mine was telling me the other day he was going to sell his bale wagon. Don't know what condition or what it looks like, but his place is in York County. Let me know--
I am in Chester county, about an hour away. I am looking for a pull type, and maybe even one of the smaller models. I'd be interested to see what model his is.
Josh
Years ago when we last handled bales, we had two of the older smaller ones.- 1005, or 1010 maybe? Totally self contained hydraulics. The most complicated machines I ever saw, but they worked well. We picked up in the field, and unloaded a bale at a time on the elevator. We had a pair of JD 2510s, so we had a perfect team. Only thing was- boy could you ever cover ground fast with the tractor and baler. NO way we could keep up.
It partially depends on what model you buy. The newer ones are more automatic then older ones. On our self propelled model, everything can be controlled from the cab. Even the forming of tie layers. Some require a manual tie, which means getting out and forming the layer by hand, and then putting it up. Some of the pull types have a fully contained hydraulic system, and only require a pto, and some require remotes. Depends on the model.
Weight is not near as critical and how solid the bales are. I've stacked grass bales that average 45lbs, and stack perfectly, and I've stacked 70lb 4th cutting alfalfa bales that will really test your patients. The key is nice, solid, square, uniform bales, and then operating is a breeze.
The most important thing to remember is adjustments. There are many adjustments that can be made to fine tune a machine, and you may have to change them, as bale length, weight, and density varies field to field, and cutting to cutting. Most of the time it only takes a minute, but you have to understand how it all works. Also, alfalfa, bales are less likely to slide around, so you have to adjust the machine to force those bales a little harder. Grass and straw like to slide, and you have to change the settings to put less force on them.
Regardless of what you buy, my dad started running bale wagons when they first came out, and ran them up until 2 years ago when I took over. We haven't found anything they can't stack, as long as they're firm enough. Stacked about 75,000 bales this year, but 3 years ago before we put up any round bales, Dad stacked over 100,000 bales in one season with one,
David
we ran a 1033 NH for many years and i worked very well with very little trouble but consistant bale density and length are very important, 36-38 inches if I remember and our bales weighed 70 plus, so if you are going to make 36" 50# bales I don't think you are going to get along very well.
A lot of good experience and advise here. I have
an older 1010 pull type. Don't buy one unless the owner can demonstrate it for you and then can coach you while you run it through all of its paces. Don't run one without oiling all of the chains and adjusting them so they are snug. Loose roller chains ruin sprockets. The manual for the older 1010 is hard to follow if you want to unload off the side onto a bale elevator. Follow the manual measurements for tractor hitch
and pto adjustment carefully.
Mechanically, the bale wagon is sort of a combination of dump truck and a corn picker.
Be very careful operating one. The first and second tables normally operate automatically
and do so very quickly.
Bob is right. It takes longer to pick up bales than it does to bale them, so ideally someone will
start picking up at the same time the baler starts.
E mail me your phone #, name & address. I'll forward it to him. By the way, in 'crawlers' forum, under the Fiat -Allis, that's him holding up the gate--
I'd go with an accumulator and bale grab. I've got a cheaper drag the bales on the ground type and love it. Stack them on the wagon 8 at a time and load them into the barn the same way.
Whatever you choose....good luck
they take some learning and really d not like the lighter bales. i went with accumulator setup and 2 grapples. All of my hay equipment is for sale now as i no longer doing it,shop time ws paying way more so concentrate their full time nowdays. let me konw if interested,baler accumulator/grapple and 5 donahue implement trailers for sale
Ive had several over the years. The problem is never the bale wagon, its always been I keep getting out of squares because I make more out of rounds. But I love doing squares so I keep going back. I disagree with the accumulator crowd. I've tried them but I dont gain anything. With the accumulator you still have to load the wagons, still have to haul them in, still have to unload them. Either you have to have enough wagons to hold it all and enough barn to pull them in or you have to have a crew hauling and unloading. With the bale wagon, I can bale 5-700, and when the loads are at the barn its unloaded and done. Thats a pretty good day for me by myself.
The learning curve is pretty steep with them. I like the 1012, 1033, 1034 and the newer ones. I strongly dislike the 1010. To me, if they dont have auto tie and push off feet they arent worth having. Right now I've got a 1034. I dont like them as well as a 1033 but the price was right.
I run a 36 inch 55 pound nominal bale. Tighter is better. I'd been running a 38 inch bale of the same weight with hand handling. A good investment is a 15 bale grapple. I picked up a used Hoelscher made for 15 on edge. Makes the system simple from putting it in to loading it out.
How do you market your rounds? I make some 4x4 round bales, and have to work a bit to sell them. There are tons of small horse farms around, and small bales will sell themselves.
Josh
I've got a 1003 and like it well. ABOVE ANYTHING ELSE: Spend however much time that is necessary getting the settings right for your bale size; and don't get in a hurry baling, or raking for that matter consistent windrows and ground speed make consistent bales and if you try to rush the baling you will make that time up with the wagon prying bales out of the bale loader because they are too long or too loose. I have help when I do hay sometimes and can't get them to slow down and not crowd the baler. Makes running the wagon not near as much fun as it should be.
Those same small horse farms are my bread and butter round bale customers. What they need is single and two bale delivery of an inside stored round with the same stuff in it as a square. It just takes a few to get them started. Once they start, they never go back.
Ive watched it happen here over a period of about 10 years. The first year I tried it, I had 5000 small squares and a hundred inside stored rounds. Sold out of the rounds by Feb and ended up over wintering a thousand squares. The next year I put up 2500 squares and 200 inside stored rounds. Sold out of both but the rounds went first. I thought it was a fluke so I tried it the same way the next year. Same result. After that I just started putting up a few hundred squares and nearly all rounds. The past few years I've put up all the rounds I can make and all the good ones I can buy. Squares are really an after-thought.
It takes some marketing, customer service, and most importantly reliable delivery. I keep 3 trucks on the road all winter. The real break for me was getting some of the bigger horse farms to make the switch to rounds. I dont sell them any cheaper than they could buy the same hay in squares, the savings is on labor on their end feeding them and of course on my end loading them out.
As to actual marketing, I keep an ad on craigslist and a page on facebook. Im listed on f.b. under the same name as on here. Mainly it lets me keep a gallery of pictures up so people can see my hay without me actually having to email individual pics.
The secret to selling rounds is to store them under cover.Its hard to sell them when they have been out in the weather for 4 to6 mo.I sold 4x4 rounds and could never have enough. sold out every yr.but they came out as green as they went in.
Josh-
Gave Ray your number- Unit he got is self propelled. Sounded like a good price for it.
Don
