How do you get the control valve out?
kenojoe
I can not figure out how to get the control valve apart on a MF50 power steering cylinder. The book says to stick a pin punch down into a slot in the spool and unscrew the two halves. The logical place for a pin is between the 2 hose ports but the holes have what appear to be steel balls in them. Any ideas!Thanks
I tried to resize them for you. See if it works.
<IMG_SRC="<a href="http://s28.photobucket.com/albums/c234/uncletomm/?action=view&current=farm_switches_0462.jpg" target="_blank">
farm_switches_0462.jpg" border="0" alt="Photobucket
</a>">
<IMG_SRC="<a href="http://s28.photobucket.com/albums/c234/uncletomm/?action=view&current=farm_switches_0451.jpg" target="_blank">
farm_switches_0451.jpg" border="0" alt="Photobucket
</a>">
the steel balls are plugs for drill hole their talking about the slot in spool look at a parts book for a snapring under seal
I just looked at the book again and it says to put a pin in the adapter hole into the control valve and unscrew the control rod. There is no hole to stick anything in. The seal your talking about is pressed in around the rod. No doubt this will be shot when I take it out,I assume one comes in the kit. Take off the snap ring and the whole thing will come out?
the parts book might show a snap ring under the seal. some times afteryou get the spool out you might have to unscrew the spool look at aparts break down to see threads
Thanks for the tip. Pulled the seal out and sure enough there was a spiral ring. Got it out and it all slid out. The book was useless when it came to this cylinder. Thanks again.
