Old,
I've got this big old Nabob can with the plastic lid still working, full of ATF. I use it when I want to dunk a piece of red steel . . . gets a little smoky for a sec. I like it for it's thinness.
Of course I've used ATF on various things through the years.
Maybe it's true about old dogs and tricks.
But if I could turn back time
And re-do the rust photos that I actually took for the forum's sake, of my freeing up of the 15 years in the rain and snow, totally seized coulter shaft in it's collar . . .
It was lying under the trees flat on the often wet ground
beside the plow when I bought it.
Nothing staged for the sake of "touting a product"
I wanted an honest test . . .
I had to use a big hammer on that blighter too
penetrated some of the rust and got moving
and then the movement let more fluid in
and warmth generated by the movement accelerates the rust cutting . . . it was seriously frozen then super tight
I had it in my big blacksmiths vise . . . love that vise
So . . . after that movement and penetrating [b:7365db6c5b]oil[/b:7365db6c5b] getting to the heart of the seizure
after taking it out of the vise and laying it down to spray it is when those dark chocolate drips started falling and then the lighter brown ones.. I'm telling you the stuff works so well that at that point you can spray down to bare metal in places without rubbing, but it's a big waste of fluid.
AT THAT STAGE you see in the photo would be a good time to switch to just ATF or Acetone/ATF. then later see how it holds up and lasts on the shaft and in the collar
through the weather down the road . . . er,
down the furrow.
But I digress
if I could turn back time and use ATF and Acetone on that very same seized up Ford 110 Coulter shaft.
Just pour it on, beat on it like I had to and then squirt some on ATF/Acetone on while catching the drips on a towel like I did
the proof would be in the rust pudding.
After 40 years of nothing but 50's machinery, I know which solution I'd put my money on. But I would happily do a double back flip if the ATF won. But hey, how dare I claim that I discovered a winning thing in the 70's when it came to rust.
This summer I'l try to find two identical rusty things
and do that side by side typical test.
Amsoil MP vs ATF
then
Amsoil MP vs Acetone ATF
Who am I kidding
in this competition
that some will pretend is not
there can be focus on winning and holding fast
than on learning a new trick.
And so having come full circle
I'd be playin' the fool again
I'd have as much trouble selling my results
As an old Ford Coulter in the rain
