(quoted from post at 04:31:17 10/13/09) I have a 35ft. tandem axle gooseneck flat bed trailor pulled by a one ton single wheel diesel pickup with regular Iowa plates.How much can I haul.I have hauled two 9000#tractors.I also have a reg cab 1ton dually that I use.Can it haul that load legally?THANKS!
[b:fcf404e895]Larry,
(2) tractors weighing 9000 pounds each = 18,000 pounds.
A trailer capable of hauling 18,000 pounds would have to
have a minimum actual empty weight of 6000 pounds
and a minimum gross vehicle weight rating
of (GVWR) of 24,000 pounds.
That is 24,000 pounds so far.
Your tow vehicle is probably rated at 10,000 pounds.
That is gross vehicle weight rating (GVWR).
So, we are at 34,000 pounds minimum for the two tractors .....
ANY combination of tow vehicle - trailer - load that EXCEEDS
26,000 pounds requires a commercial drivers license in MOST
states.
So, even if your trailer is EMPTY, if your TOW VEHICLE and TRAILER
combined have a gross vehicle weight rating (GVWR)
in excess of 26,000 pounds - you need a commercial drivers'
license in most states.
IF you don't have a commercial drivers license & you are
stopped and inspected - you will PROBABLY get a ticket
for not having a commericial drivers license.
This is just addressing the necessity of having a CDL
in most states.
Equipment is another discussion.[/b:fcf404e895]
