how much fuel to 820 without damage
greendiesel
any recomendations on how far to open the racks on 820 diesel without a chance of a hydrolock condition (or other damage) it is at 14 right now. i just rebuilt the engine last year and it is in good condition. i would like to turn up the rack for pulling it.
Which size of pumps and injectors?
With extra fuel the engine will require all the air it can draw in and push out.
Has the aircleaner mesh been washed out with kerosene to remove several decades of mud? The inlet pipework can get caked with dirt too.
An real Deere oval muffler or a straight stack won't hurt.
it has blackdash pumps (13mm) it is converter to a k&n dry filter. the intake pipe has ben cleaned (hot tanked) and it has a strait pipe.
Pretty much put it on a dyno and move the rack until HP has almost peaked.
The EGT's can get plenty high for reliability sakes.
Valves, cam and port work would be next.
Which injector nozzles? I wouldn't dial 13mm pumps up on the little 5 X 10 thou tips used on the 10mm pump.
I know several people who have taken them as far as they will go - 22 or something like that. Worked fine. Since then they have gone in and cleaned up the head and all that black smoke goes away... works nice. No numbers though. Should see a dyno later this summer.
Full stroke 13mm pumps on 5X10 thou injector tips? Or full stroke 13mm pumps on 6X12 thou injector tips?
The big pumps on the small tips add too much load and pressure. On the cam, followers, pumps and lines. One of the things found when mystery leaks keep occurring from the pumps and lines into the crankcase.
If you know of many tractors running 22+ racks fine there. Why are you asking if it's ok here?
I'm not asking. Just saying what I've seen. Also, anyone up here who has switched to 13mm pumps has also switched to the larger tips.
One 830 with factory equipment turned up all she will go. Another 80 with 830 head, pistons, pumps, injectors turned up all she will go. Both have had a good polish job on the intake and exhaust runners and now make very little smoke but lots of power. Both run 2nd gear very well from 8500 lbs to 10,500 lbs.
i have not switched to 13mm pumps that is what the tractor came with as well as the 6 hole .012 tips (this is a black dash 820) and yes the portss in the head have ben polished up and gasket matched - has new factory size valves and a reground cam (from berry cam in minnesota) with a more agressive grind (i gave them the information and they picked the grind)
wow the weight on your 830 (down to 8500) did you have to remove anything to get it down that far? my 820 weighs 11,900 (with 3 sets of wheel weights and some (not full) fluid in rear tires. does it doo better in the lighter weit class or the heavyer one? i always spin out and the front of the tractor is always in the air (need more weightin the front to keep it down) i run 1st gear (no creeper gear set) have 18.4 34 tires.
My father's 820 will get down to 7500#, 7000# if we take off the mounting brackets for the wheel weights.
Terry
I have a set of creeper gears if anyone is looking. Would like to sell them to finish another project. 410-463-1897
