How to dismount a ford loader
I would imagine someone had to a bit of
engineering to fit tht ford loader to the John Deere
without a picture kinda hard to tell . A big tree or
another loader tractor or overhead hoist will be what
you?ll want to start with
All right thanks for the advice. Now maybe I should have said that it is a 776B Quick Attach. Does that help or make a difference in how I go about taking it off the tractor?
See if you can find an owners manual for it and also a parts book, possibly on line. With that you should have no problems as it will tell proper procidure for removing or mounting. I don't know anything about that loader. The Dunhan I had on a Ford was simple to see how to do it but not all are.
Since it?s 2 different manufacturers cobbled together, we would need a picture to see what parts are there to work with, more blue parts or more green parts thrown into
the mix......
Then too we could draw on your pic and point tot he starting points, etc.
Paul
If it was like the Ford loader on a 7700 I ran for years you set the bucket flat on the ground and pull the lock pins out, then Slowly back away while "raising" the loader arms, this will allow the sub frame to go down to the ground and hold up the loader when stored, some have both sets of hoses long enough to back out all the way others you have to unhook the bucket hoses, shut off tractor when you are clear of the sub frame then carefully work the remote lever or levers to relieve the psi on them unhook hoses and hang on the loader. Other models have stands ect,, you should be able to order a ops book from a cnh dealer for the loader operation
cnt
I may have told you about the one Ford we also had with the Leon loader,, we had three tractors with loaders, I do not rememebr any stands on the Ford loaders we had they all would stand on their own, always remove it on the most level place you can
