how to id an injection pump
gtrace230
How can you tell the difference between an indirect injection pump and a direct inj. pump.
I have a direct injection 3 cyl perk. angled injectors. I ordered a brand new pump. And it has what looks like some sort of regulator mounted to the bottom. My pump does not have this. Also the old pump has a valve(pressurizing stud instead of a banjo bolt holding the fittings to the lines. Which is better, or is needed? The salesman told me this pump is a newer version,however looking at my parts book it appears to be an older version. thanks
What was the problem with your old pump and what is the CAN model number? (for both pumps) Pumps don't care if they are direct or indirect injection. That refers to the design of the combustion chamber. There is more to it than that. J. (Send me an e-mail address.)
Email is [email protected] and I will tell you the history of the tractor. It was sitting apart,head off for app 10 years. the orig pump is cav. dpa3230240
set. sw57/700/6/2160 mod- left blank?
ser. 21861xm.....new pump is ipm?
dpa 3238f510... ser jz210...mod 478
ww49l/900/3/2500 thanks for your help. George.
