lastcowboy32
We have a Chinese-made tractor on the farm that we used up until a couple of summers ago.
At that time, we just had that and a Ford 2N... and we were baling something like 3000 bales a year. It started having mystery heating problems, losing coolant, etc. It also had an issue where the oil pressure would start out at 40-50PSI and then get down to 10PSI as soon as it warmed up. I took off the head and had it checked out at an engine shop, the head was fine. I replaced the head gasket and put the head back on. There were no leaks from the head gasket... but the problems persisted. So, I'm positive it's not a head issue.
At 28hp...that little tractor was overmatched. I can't blame it for puking out after running a 7 foot haybine and a NH 276 baler for a couple of summers... all it did before that was mow lawns and move a little snow. All of the bearings, sleeves, rings and such were probably just plain worn out...given how the oil pressure drops like a rock as it warms up.
At that point in time, I had enough money to either fix this tractor, or buy a used Ford 3000. Given that the Ford 3000 was bigger, more horsepower, etc, etc. I went with the Ford. We also now have a Ford 4000. We also did an in-frame rebuild of the Ford 2N, and that's been running like a champ.
So...now... I'm looking at this little 28hp Jinma sitting next to the garage and thinking... I should get it back up and running over the next month. Good project to get done before we start building fence in April.
I looked up parts. If I tear down the block and replace all of the sleeves, rings, bearings (main, connecting rod...etc) parts will run me about 600 bucks.
If I replace the pistons, connecting rods and all of that hardware as well... that's almost another 500 bucks.
Is there a way to inspect or test the pistons, once I have them out?
I mean, in my little Ford 2N...I kept all four original pistons... cleaned all the deposits... just replaced rings, bearings and such.
I don't want to replace the pistons just because I'm in there, but I'd like to think that I did my due diligence in inspecting them.
