DoubleO7
- Location
- Crystal River, FL
This is for a 1957 and it does not have the gated shift tower.
I have the five speed shifter on the work bench.
The right hand rail moves like it should.
But the center and left rail do not move linearly, just partial rotation.
I see there appears to be a steel pin thru each fork casting going into the rail shaft.
Does that pin have to be drilled out to pull the shaft out??
I suspect the detent springs and/or ball bearing hidden in the rails are rusted up or damaged resulting in them not allowing the rails to move.
