Hi, I know this has been discussed before, but how do you remove the 3 bolts with rubber bushings with sleeves that hold the adapter plate to the pulley ?
I cannot get a socket on the bolt head because of the rubber bushing around it.
If I do get the bolts off, will the plate slide forward with the shaft enough to fit a new belt through ?
