How to reverse an electric motor
i have a Tamper ac motot 115 v , 7.3 amp. its model is SP-D56E SAK
i want to reverse the direction of thios motor and don;t know how. it has a two pronged hook up on the out side and when i split it open there is a white wire, yellow wire and black wire
what to do?
Some motors are not reversible, but most are. Most have a diagram on the inside cover of the little box where the wire goes in. Tells which wires to switch. Some also change in there for different voltage.
Won't change a thing unless the winding supply to only the start winding or only to the main fields is swapped.
Swapping L1 and N at the input cord will change nothing.
Last one I reversed, I Googled the make and model of the motor. It got me a site that had all the connection diagrams I needed.
If it cant be done electrically it can be fipped around backwards.Usually wont fit on the mounting plate then.I know thats not what your looking for.Some just dont give you the leads to do it or access to switch wires.Google it and you will come back to your own post probably.
