How would I start this Kohler K-321 AQS engine that I pulled out of a Cub Cadet 1450 quietline parts tractor? I have ghenengine on the engine on the bench and want to test it. I filed the points and checked the wiring diagram and found the coil gets battery power from the switch and since it's out of the tractor I just used a jumper wire from coil (+) to battery (+). I then put a large jumper cable on a bolt on the engine head and the other end to the (-) battery post. Went around to move points to see if I had spark and it sparked and the "spring" part of the points that allow them to move caught fire and warped. The little harness plug that you see goes to regulator piece.......2 outer wires went to the stator on the engine so I left those unplugged since it has been removed. The middle wire on the regulator piece goes to negative side of coil.
