grandpa Love
Several folks asked,some genuinely wanted to know,some want to point out everything we did wrong, how we cleaned that head up. We pulled the head off, sprayed it with purple power,hot pressure washer, dropped it in a tub of vinegar for a couple days,hot pressure washer and into a tub of old motor oil. Pressure washed again,blew it dry , removed all the valves,cleaned them carefully with a brass brush on a Dremel. Lapped the valves. Used a brass bristle brush on a drill to clean the rocker arm assembly. Oiled it ,made sure oil oozed out everywhere is was supposed to. Keep in mind, Renee is in the shop too ,she is working on one part while I work on another. So...... technically we had 4 "man" hours in it over several days ( when you count soaking and pressure washing) . We also pressure washed the block out, tons of sludge, rust and mud in there. Oil pan came off, sludge cleaned out of it , too. We keep detailed records of what we do,and give a copy of those records to the customer. We ain't hiding anything. And folks are impressed and surprised at what we accomplished
