Hyd. system
Anonymous-0
Had a Bush hog loader No.# 2846 Q T mounted on my New Holland 6610 S tractor. The dealer tied into the external hyd. instead of tying directly into the hyd. system of the tractor. The dealer that installed the loader is not a New holland dealer but i do a lot of business with them. They told me you couldnot tie into the main hyd. on this type of tractor. I know a little about open and closed hyd. and i know it can be done. The external hyd. comes off the hyd. maniflod under the seat and has other plugged outlets around the maniflod. Can you direct me how to tie the loader hyd. into the main tractor maniflod?
Thanks,
E. C.
Most loaders run off the aux. hydraulics. Open center and closed center refer to the type of hydraulic valves and pump you have. I don't understand your post. The aux. hydraulics still come from the main hydraulic system. Industrial loaders usually have a front mounted pump and an independent hyd. system. Are you wanting to have the hydraulics go straight to the loader and leave the aux. for other implements? You'd need seperate control valves for the loader and maybe a power beyond adapter. Dave
Thank you for your response. The bush hog loader has its own seperate control valves. It works from a wooble stick.There are 2 hyd. lines that feed hyd. oil to the control valves of the loader. They are plugged into the tractor aux.hyd. and the lever that operates that set of aux. hyd. stays locked in to provide hyd. power to the loader control valve. Yes, I want the hyd. to go straight to the loader conrol valves and this leaves the tractor aux. hyd.for other implements. There has got to be a way to do this.
Thanks,
E. C.
