GASTON
hello everyone,when starting my 560 i have to release pressure to allow the engine to start, and after a while the engine dies cus it has low piston compressure. the engine is going to be rebuilt ,what do i have to do to the hydralics. thanks for any responses,gaston
You have 2 problems:a wornout engine.and more serious,a sticking hydralic reliefe valve(located on the left side of the hydralic valve bank)You need to get that repaired soon!The worn engine can wait-it will run better if the hydralics are working properly.Good luck!
That tractor doesnt have a 'float'.it is power up-power down.there is a pin you can pullout down under the lower cylinder pin.
