hydraulic cylinder ring question
its leaking enough that it will creep down at idle with a bale on the forks. I can take the side cover off and see a trickle of oil from the cylinder. There is a set of improved rings listed.
While you have it apart to put in the new rings be sure the cylinder isn't split and the cylinder bore is straight and smooth or the new rings won't last long.
Gerald J.
