Hydraulic filter , front end loader ID help
qaz3000
Hello everyone, new here.
I was wondering if anyone could help my identify my front end loader on my case 410 B. I know its an original JI case fel but the model number on the plate is gone. The serial is 4012134.
My hydraulic pump is whining like crazy and is very slow , I've just replace the fluid and rebuild the 2 loader cylinders but it did not help at all I would almost say its worse. Im trying to identify the pump also. Says its a webster.
I've looked everywhere and cannot find a hydraulic filter I've owned the tractor 6 years and the previous owner did not maintain it so im sure if there is a filter its plugged
forum wont allow me to post my pictures , they upload just fine but then they tell me it contains restricted words..
Make a few more posts and keep trying your pictures, you can use the Test Forum, down at the bottom of the list, to try in. The site has some spam filters that often require one to have more than 5 post on record before they can post pictures.
hope it works this time !
Do you know if there would be a hydraulic filter behind the round plate bolted on the external hydraulic tank underneath the tractor shown in the pictures ? I've followed all the hydraulic lines and the only component that is on the lines is a one-way valve which I've opened to make sure there is no screen and that it is working properly.
I think the loader was taken from another case tractor but im not sure.. I would like to order the parts manual for it on ebay, a bucket cylinder is missing 2 parts and the pump will probably need a rebuild/replacement.
