Hydraulic oil
Anonymous-0
What would the color of hydro oil in a 3020 should look like. Mine is kind of clear brown like tea. Should it just be clear.
You likely have a little water in the oil. It makes the oil turn a milky brown, disgusting color. Do you know when the last time it was changed?
I dont know when it was changed. It dont really look like water in it. Its not milky just a clear color with little brown. Like weak tea.
Sounds like your hyd oil is OK. Hydraulic oil made from Grade 2 base oil would be perfectly clear. The additives do not color it. AGCO hyd oil is made with Grade 2 base oil so it is clear,
is practically the same as JD hyd oil.
