I have a 401 b yellow John Deere tractor and I have a loader to put on it and I think the two spool valve I have is open center valve and the tractor is closed center. Is there any way to hook it up and make it work my valve does not have the plug to change it from open to close. What would happen if I did find the preasure line off the front pump and made the oil flow through the valve . Would that not work ? I think if I tied into the preasure line and returned to the sump that would not work or would it? Some body told me you can use a open center valve on a closed center tractor if you knew how to hook it up .Is that right ? If I do need a valve where is the best place go buy one and what do I need to ask for as like pressure and that kind of stuff ? Northern tool company sells them but I do not know which one I might need . Thanks
