hydraulic remotes
Do you have a mnaual? Does your power steering work? You have an internal leak. You need to find it! If you do not solve the problem shortly you will ruin the pump. Do you have any pressure gauges At least 2, one being at least a 3000 PSI gauge. How well do you understand a closed center system?
Thank's for responding, I don't now anything about this system. I have all hydraulics, except the remotes. The tractor will not lift my disk.
