JimFord555
1979 555 backhoe lost all hydraulics suddenly (if I rev it up I can move the loader up and down slowly tilt the loader and get small movements out of the hoe side to side and bucket curl but can t lift the hoe (machine runs perfect)
Fluid level is good
Checked the tank for a plugged screen or loose baffle restricting fluid
Pulled the pump and went through it video of it sent to to a heavy duty mechanic and it looks all good
Removed disassembled and cleaned hoe and loader system over pressure valves (no broken springs and all the poppets seemed to move freely
Switched the hoe system over pressure valve (2400psi) for the bucket curl over pressure valve (2375psi) and still nothing works
In the back hoe manifolds outlet cover I checked:
-regenerative check valve on the side
-back pressure valve on top
-unload valve on top
These are just visual checks by me and springs and poppets are all in good working order seemingly
Connected the main hydraulic hose coming from pump back to the hoe manifold inlet but left the power beyond port capped and capped the hose that connects the power beyond port to the loader manifold. The hoe worked For a minute then stopped and the machine died. I m thinking there isn t enough return path for the fluid withought the loader manifold connected and I created a bottleneck. Any idea if this is correct or an indication of a problem?
I have a mechanic friend coming over with a flow meter but if the machine runs the loader normal without the hoe connected it makes me think the pump and loader are fine and the hoe manifold is letting fluid bypass somewhere so I can t build enough pressure for anything to work properly.
Any idea of what to check next would be very helpful I ve checked everything I can think of at this point, what in the hoe manifold is capable of bypassing fluid ?
Any low or pressure checks that can help diagnose ?
Fluid level is good
