Hydraulics on Farmall C
SDP1
I recently put a fast hitch on my C and now need to plumb the hydraulics. Looks like I need two 1/4" lines at least 5 feet long to get to the pump. Anybody know what couplers I need to the pump? They look like quick couplers but not sure if they are male or female. Will Pioneer, Parker or DNP work? I've never plumbed hydraulics before so am kinda lost.
As the others say the plumbing is done at the unit under the gas tank, you need a bypass block. the type of connections is not important as long as the hose connection fits it. Unless you are using a lot of different trailing implements, then they all must be the same.
