Alex.C
My Oliver 1900 has a problem. When the hydro system is cold it works fine but when it gets warm I have to rev to near full throttle to get the 3-pt to lift. I don't know why it does this but when I was moving hay last time we got a load, it nearly stop working on the last round bale. Now I haven't replaced the filter yet but I don't think thats the problem cause if it was it would act like that when cold. Any Ideas??
Alex
Sounds like a worn pump. You might get by using a heavier weight or multiweight oil that doesn't thin out as much when hot.
Gerald J.
Has the hydraulic filter ever been changed? A blocked filter could cause that problem as well.
The hydraulic filter is located above the rear axle, on the left had side of the tractor.
It is in a pain of a place to get at. It is tight up against the platform.
I found out that my Cockshutt 1650 had one, was last winter I put a stick through it, while in the bush skidding out tree tops. Bruce.
Make sure you have the right fluid in the hydraulic system.My Ford 640 had the same problem with 134 fluid in the system.My owners manual called for an 80 or 90 weight GL1 oil.Many Ford owners had no lift at all when they put 134 in the system.CNH reccommended the thin 134,Ford never did.Look at your owners manual and use the oil it specifies.My tractor lifts my cordwood saw at idle.Always had to be reved up to lift with 134.In hot weather there were times when it couldnt lift the saw.
