I bought a new water pump for my Super C. Old one was stuck when I got it. I got it loose and used the tractor for a while but it was making a lot of noise and had a lot of corrosion so I decided to replace
it. First problem is the way that pump was designed. One of 2 bolts is in a place that requires removing the pully which requires splitting the pump to get it out so the new one comes with the bolt already
installed. Problem is there is not enough clearance on the new pump to get a wrench on the bolt to get it tight. Its made so a boxed end wrench is the best wrench and you can't get one on the bolt head. It can
be turned a small turn at a time with an open end wrench but you can hardly turn it enough to get another grip and when the bolt gets to the end of being tight you can't even do that. It wasn't any problem on
the original one. I tried to grind down some cheap wrenches but couldn't take enough off. To make it work I put in some lock washers I cut in half for spacers and finally got enough in to make the bolt tight.
With the two cut lock washers and the correct lock washer there is about a 1/4 in of bolt that can't be tightened down with out spacers. I can't believe it is that hard for a company to make this stuff right.
