I decided to get my granddad's planters out and try to plant a few acres of sunflowers for a dove field. I was never taught how to set it up or operate it. Sadly, he passed away before I was born. I found out that Yetter bought the patent and their manual is close to the same as the original JD planter. However, my unit looks a little different so I don't believe it operates exactly like the Yetter 71 does.
I used the unit last year with everything set as it was last used except I installed the correct plates for sunflowers. I had a decent stand but I believe it was just beginner's luck. This year, I tried to improve a few things but believe I don't have the planter setup correctly or as good as it should be.
I don't know much about farming but here's the information I know. The planter is a 3 pt 4 row unit, 36-inch row spacing has two toolbars, both square but oriented like a diamond with the front one used to mount 3 pt hitch and fertilizer boxes. The back one is for planter units. The planter units have round fiberglass seed boxes with black plastic lids. The 2 metal fertilizer hoppers were removed because they were rusted out. The planter also has 2 hydraulic row markers, 2 gauge wheels?, and rectangular 'skid' type plates under seed openers which I believe set the seed depth?
I haven't found much on the internet that looks like the same model I have. I'm not sure if mine was modified or what. I've thought about removing the 'extra' parts to get it to look/operate closer to the Yetter 71 model, but wanted to get someone to weigh in who knows better than me.
Thank you for your time and I appreciate anyone's advice.
Billy
Here is an example of the skid plates shown better on an image I found on Google.
This post was edited by wcaughman on 04/25/2022 at 07:52 am.
Billy
