My MF202 with a Z134 Continental engine is running rougher than a corn cob. It skips, the higher the RPM the worse if gets. This problem just happened overnight and the weird thing is that once or twice ran okay then back to same problem.
Engine was replaced less than 6 months ago with a totally rebuilt one. New distributor, all new plugs, wires and coil, installed a carb kit. It ran great until last week.
Here is what I have done so far:
• Checked spark at the coil and output of plugs. (Good healthy blue sparks)
• Removed carb, soaked in cleaner and blew all the jets. (I was real clean inside anyway)
• Adjusted air/fuel several times.
• Used a small troubleshooting tank with new gas, just in case.
• Sprayed starting fluid on carb and manifold. (No increase in RPM)
• Checked all fuel filters.
• The carb is getting plenty fuel in the bowl.
• Compression dry test, 110 - 115 psi across
• Adjusted timing at the distributor. RPM goes up and down but problem still exists.
I am pretty sure that after checking and rechecking fuel and spark components, they can be pretty much eliminated.
My uneducated guess points to the timing, but what???... The distributor is almost new. (I didn't pull it and check it). I just hope it is nothing internal.
I tried to follow some sensible troubleshooting procedures, but I am just running out of options.
I just hope you gurus can come up with something.
