lastcowboy32
This is anecdotal, just based on what I read here.
Seems as though many posts start with, I was mowing when... x happened.
My experience with our 2N is that it doesn't really handle a mower or bush hog very well. The only mower that I'll use on it is our 5' finish mower. Even then, only when the grass is low. I tried it with a bush hog...once...and that was scary.
It strained to lift it.
It strained to hold it up.
It strained like mad to get it going.
Thankfully, it was a borrowed Bush Hog, and we had a bigger tractor to put on it. So I wasn't "invested" in this. I stopped after about 1/2 hour and switched up.
If I had used that bush hog for any number of accumulated hours over the years, I'm convinced that I would be splitting that 2N and replacing the clutch at a minimum, and also risking big/odd failures like broken gears, shafts, etc.
Why?
Well, after my little adventure, I went to Tractordata.com and checked out the N series.
The 9N/2N are tested at about 20 PTO HP. The 8N tested slightly higher at 23 PTO HP.
Most people that mow with bush hogs want something as wide as the tractor...which means at least a 5' bush hog with an N tractor.
Well, checkout the ratings from the Bush Hog website in the attached photo. That BH110 series is new, designed to cut 1" diameter stuff. That's the only series that has a model rated for an N-series tractor.
Now, yes, I know that a 20HP N-series tractor is heavier than a new 20HP tractor... but... they are also 70-84 years old. Also? 1st gear isn't very low, so you can't use ground speed to regulate the load on the driveline...unless you have a Sherman step-down...which was rare.
(also... many people fail to remember that, when you use the step-up...the whole driveline, including the PTO speed steps up... so you're trying to run that bush hog at something like 850PTO RPMs... which is a BIG, BIG load on the drivelines)
Moral of the story is... use an overrunning clutch at a minimum... and any Bush Hog that you buy used? Check it's HP rating and use at your own peril. Also... always use mowers and stuff with the step-up transmission in Low.
Why?
