lastcowboy32
I get what you're saying. I should say that my own opinion was formed from a couple of things.
1. When I started using Bush Hogs, it was on my father's farm to clear land that he rented that had sat fallow for years. My brother, when renovating these fields for dad, liked to do it in late August, early September, using winter rye as a cover crop over grass seed. So there I was, looking at acres of weeds, saplings, hidden stone piles, shrubs, etc. My brother sat me on a JD 1520 and gave me a few instructions. One of which was, if the tractor can drive over it, the bush hog can take it. And that I did. Ear protection? Nah... this is the early 80's. So hours and hours of dust, chaff and noise from whacking saplings, stones, ant hills... At the end of the day, tractor and bush hog were just fine, but both were used to their capacity.
2. Fast forward 35-40 years, and my wife and I got the opportunity to use a 60acre field for hay... but... it was no-tilled to corn two years before and left alone. It's early June and it's grown up to all sorts of weeds. I pull in with the 2N and a heavy duty bush hog that I borrowed from a neighbor. I figure that it's not saplings, how bad can it be? Well..plenty bad. The old N was grunting plenty and getting hot.
So... why would I look at doing 60 acres in 1st gear, cutting partial widths? The bush hog was rated for a bigger tractor... which I had... and I was able to travel at a reasonable ground speed taking full widths.
So... sure... you can cut with a 40hp rated bush hog with a 2N... but you're going to have to do tricks to get the load on the bush hog down to 20hp... set it really high, take partial widths... mow often... But, if you take a 2N out to do 40hp rated work with a 40hp rated bush hog? Well bless your heart.
