ID this 8N carb please
Looks more to me like a Zenith than a Marvel, but doesn't say Zenith on it.
Want to get the rebuild kit and get the right one.
I fairly recently swapped it for another one I rebuilt, so now it's this one's turn.
Thanx.
IO think it is a reproduction of a MS carb. Not a Zenith. I would try a basic MS carb rebuild kit.
Scrape all the crud from around the outside of the mounting flange and see what the # say on there,looks like a M/S to me.
[b:f8c819c60b][i:f8c819c60b]
Charlie;
If you go to YT parts, and look under carbs, you will see a carb there that has a part# of (wm-8N9510C) !! Listed for $133.??
That is what you have there!!
Takes a standard TSX33 carb kit, and is an 'AFTERMARKET' carb, NOT a Zenith, nor a Marvel Schebler!!! Manufacterer UNKNOWN!!
Think those are a 'pot metal' casting, and yes the early ones are/were, of a heavy nature.
Not too bad a carb, for an aftermarket. Smooth passages and easy to overhaul/clean up!!!!! I have done a couple, of those, with good results!!
BTDT!!!
HTH
Gary :wink: [/i:f8c819c60b][/b:f8c819c60b]
cool, thanks Gary.
If I recall, I got that used from Wenger's, and it was on the air for about 5 years, very happy with it, got it for a good price.
(quoted from post at 17:50:01 02/17/13) cool, thanks Gary.
b:5e8bec26ed][i:5e8bec26ed]
If it will make ya feel better.......that particular carb, is the ONLY 'aftermarket' carb, that I will even concider, for overhaul.
My FIL, has one on his 8N, and loves it!!!
Gary 8) [/i:5e8bec26ed][/b:5e8bec26ed]
