identification Caterpillar D6
CAROGATOR
I have a D6 Cable cat w/hyster D6N winch on rear only # tag I can find is on side of engine at left rear. Says D6 9U 9262 . Can anyone help I.D. this machine? Thanks
Any CAT dealer, and CAT might have the info online- the serial # is all you need, as all ID for parts etc. is by the serial #. 9U is a real good machine, if you have a Hyster winch on the back, you probably have a #24 cable unit on the front. Engine is a D318, with a pony starter unless it's been converted to direct start
Look at the front of the flywheel housing and see if there is a cover held on by three studs and nuts or just a raised portion of cast iron in that shape. If you have a cover to take off you can get a starter with a special gear(spiral tooth) to bolt right on and just wire up. If not you need to make a hole and drill bolt holes. Not something I would recomend, Old Magnet has all the parts sourse info you need.
Later Bob
Thanks for the info. thanks also to bruce oz. those sites will fix me right up' sorry it took so long, but the site stopped recognizing my password. had to correct.
