Idler Pulley Assembly Super A
JTE87
Any idea where I could pick up an idler pulley assembly/mule drive for a Farmall Super A?
Messicks has parts for the Woods brand mowers and some parts would interchange with other brands or could be adapted. The Woods L59 and L306 both could be driven with a similar mule drive setup.
Do you just need a pulley, or the entire thing? You state "assembly" which I take to mean the entire assembly.
Also looks like you're looking for parts for a Mott flail mower.
If either/both are true, good luck. Unless someone happens to be reading that happens to have one, the only way you're going to find such a thing is by random chance. Your best bet is tractor show swap meets, flea markets, and estate auctions where the deceased was a Farmall collector.
Yes, I'm needing the entire assembly or something that will work. Not too many Farmall guys that I know of. I've never heard of a swap meet nearby.
Can you find pulleys and have welder/fabricator to fix you up on the rest of assembly?
Probably. But, with what the local welders want to charge, I would probably be able to buy a second Super A. They wanted to charge a minimum of $400 to drill 2 9/16” holes in some heavy steel.
Do you already have the mower? The drive should
have come along with the mower.
Grandson bought a locked up A just for the mower
& drive. Still had to make adjustments.
Jim
Jim
It's with Fastenal right now on its way. It's my understand it's not there.
