(quoted from post at 05:55:02 03/31/13) HI have leak from were 3 point lower bars bolt on .3 point lowers when motor is off
You have two separate problems.
The oil leaking externally is the sealing rings for the draft control torsion tube.
The hitch settling with the engine off is a leak in the hitch cylinder or circuit.
Good new.... when you have the hitch cover off to fix the settling you will be able to see better to replace the o-rings and, if needed, bushings for the torsion tube.
Dougl As has been said you have 2 different problems. The external leak at the lower linkage has nothing to do with the hitch going down with engine off. You can fix the external leak from the out side. You will have to pull the torsion bar to fix that. To fix the leak down of the hitch with engine off, you will have to pull the top off of rear end. Hope this helps.
