IH 130 wiring
Buggy97
Could someone please post a wiring diagram for a 6 volt positive ground 130?
Things were working fine but all of a sudden wont start unless I bypass the kill switch on the dash which has one wire to + terminal on the coil and one going to the voltage regulator with a jumper from - terminal on the battery to the + terminal to the coil
I did test the switch for continuity and it seems to be functioning properly
With positive ground the + post on coil should go to side of distributor and - post to switch.
It is possible for a switch to check good with ohm meter and still not work under load.
How did you test the switch. You should check with lowest range on meter and it should show near 0 ohms. If you had your meter set on a higher range it is possible for a high resistance switch to still show continuity.
Also check for bad or broken wire connections.
No mag and it worked with the switch connected to positive on the coil and negative to the side of the distributor
There is a wiring diagram for a cub in the post attached. It may not be exact but should be darn close. I have no idea if the colors are correct if that is what you are looking for. As for the coil it will run fine with the polarity reversed. But to have optimal spark and points life on a positive ground system the plus terminal of the coil should connect to the distributor, as is shown in this diagram.
Poke here
