IH 2pt plow
In a four bottom, you might want to consider a semi-mounted.
I bought a four bottom 3 pt. John Deere plow once and put it on an 856. I made a half dozen rounds, took it back, and traded it back for a semi-mounted. The three point was just too much weight swinging around behind the tractor.
Most 3 pt and two point implements have the majority of the weight tucked in right behing the rear wheels, so it"s manageable, where a plow sticks clear out behind.
If you insist on trying it, you"ll need a LOT of weight on the front end of the tractor.
My two cents worth.
Where are you located? I know of one but don't know if the guy will sell it and its been sitting outside for quite some time.
Naw,
Think you just weren't used to it maybe?
An 856 would simply play with a 3-bottom plow.
They "look" heavier than they really are. Not nearly as heavy as a 6-row cultivator or a loaded planter.
Allan
