You are going to have to explain what you mean by
nothing happened. If you are moving the lever in the
video you are not showing us that. It does not seem to
me like the machine ever surprised you by stopping.
When you pull the lever back it should reduce the
speed noticeably. If it does not then I would say the
most likely problem is the TA direct clutch is stuck
engaged. So just like a normal clutch in machine can
stick when it sets a while so can the smaller TA clutch.
Second problem may be that is simply out of
adjustment. Someone else will have to chime in to give
you the proper procedure for that. Lastly it is possible
the something has broke on the TA clutch release
mechanism. It has a throw out bearing and pressure
plate just like a main clutch. Right now my uncles 300
has the pivot points for the clutch release levers of the
TA pressure plate broke off. Two of the three are
broke, if you forget and pull the TA lever back you can
feel a wobble in the lever because of the uneven
pressure on the TA throw out bearing and of course
the TA clutch does not release. This means the TA
stays in direct similar to yours. In the link the small
cover that covers the TA dry clutch is number 19. I am
not sure why but the parts list says the diesel cover
has a different number than the ones for gas engine
machines. I am not sure what the difference would be.
CNHI IH 350 clutch housing diagram
