IH 424 Shifter Forks
Anonymous-0
I broke my IH 424 apart to work on the PTO and now putting back together, all was well until i put the shifter forks back in and now seems that i must have moved something either in the tractor or the forks. i was able to move forks to put back into neutral and now once tractor back together it does not go in reverse and to get out of gear you have to put hi-lo range in neutral.....I NEED HELP!!!
Obviously, at least one of the shift forks missed the goove it's supposed to be in.
You'll have to remove the cover, slide the gears to their neutral positions, and carefully put the cover back on, matching the forks to the grooves they are supposed to be in.
