Welcome to YT forums and ASAP parts. If you have remotes on the tractor, and two of them are free, you can hook the loader up to them with standard couplers. If not you will at least need a power beyond plate and hoses to make it work. We really need much more info to be of direct help. Jim
I have rear hookups that are free
The tractor had a trip lever setup run off controls under the seat
I bought a all hydraulic loader with controls on it that I want to plumb in and not have to use the controls under the seat
A "power Beyond cover adds hydraulic outlet options. I do not know the exact part # for that tractor. Jim
Hi, welcome to YT, require some photos of existing hydraulic system on your 424 and the hydraulic valves on the loader .
The 424 came with many different hydraulic setup, photos of front of seat, under seat on left and right sides and rear remotes and loader hydraulics, valves, single or double acting cylinders on the boom.
Without seeing your setup, the basic way was tap the pressure line off the pump thru the loader control valve which normally comes with the loader, then from the loader valve back down to the three- point control valve where it originally went. In other words, you're plumbing the valve in series with the tractor hydraulics.
Depending upon the valve, you may need to procure a "power beyond " fitting for the outlet side of the valve.
