RECENTLY PURCHASED A IH 454 UTILITY TRACTOR THAT KEEPS PUSHING HYDRAULIC OIL OUT OF THE BREATHER UNDER THE OPERATORS SEAT. ALL HYDRAULICS SEEM TO BE WORKING OKAY. THE PTO WORKED WHILE HOOKED TO A 10' BRUSH CUTTER(JUST SITTING IN SHED), RAISED AND LOWERED 10' CUTTER OKAY, STEERING SEEMS TO WORK FINE, 3 POINT WORKS OKAY(NO WEIGHT ON IT), HAVE PULLED MC VALVE OFF AND TRANSFER PUMP SCREEN LOOKED CLEAN, BLACK RUBBER SEAL ON BACK OF HYDRAULIC PUMP IN GOOD CONDITION, BLEW OUT HYDRAULIC OIL COOLER LINES, CHANGED HYDRAULIC OIL AND FILTER. ONLY DROVE TRACTOR UP AND DOWN ROAD. TRACTOR STARTS TO DOG DOWN WHILE IN 4-HIGH WIDE OPEN. I THINK WOULD KILL TRACTOR IF I DID NOT CLUTCH IT AND IDLE DOWN. NOT SURE IF THIS IS RELATED BUT SEEMS TO PUSH MORE OIL OUT THEN. CASE-IH DEALER THOGHT REAR END WAS OVER FULL. NOT THE CASE SINCE THE SECOND TIME I CHANGED HYDRAULIC OIL, I ONLY ADDED 8 GALLON WHEN IT CALLS FOR 9 GALLON. TRACTOR SAT ALOT BEFORE I BOUGHT IT. HYDRAULIC OIL LOOKED KINDA MILKY WHEN I DRAINED IT FIRST TIME. SEEMS TO ME OIL IS NOT GETTING OUT OF THE REAR CHAMBER FAST ENOUGH. ANY IDEAS, SUGGESTIONS OR ANSWERS ARE WELCOME!!!!! THANKS
