Theodore51
Hey all,
I've been doing tractor stuff for a while now, but until recently I thought I knew what I was doing. I bought an International 504 utility model with these options:
Power steering
Rear and front remote hydraulics
Independent PTO
Live hydraulics
3pt
Torque Amplifier
I bought it for my dad who has always wanted a tractor with these options. The only problem is that this one quit when we were trying to fix the headlights. I tore into it a few days ago, after I ordered a new Pertronix ignition kit and the coil to go with it because I thought the coil was the problem (the kit and coil haven't arrived yet). Turns out the spring holding the points open in the distributor was broken. I put a coil spring in to see if the tractor would fire and it started up, even with the year-old gas in it. I drove it for a while and it died again, and after cranking on it, the cranking motor decided it didn't want to crank anymore and whenever I pushed the button for the starter nothing happened. The wiring in the tractor is a mess and even tapping the solenoid and messing with the wiring now does nothing. I realize the wiring should all be redone but I can't find any wiring harnesses for sale for an IH 504. Thoughts on this?
Also, sometimes while trying to start the tractor the starter will grind and I have to wait for it to spin down before I can try again. I hope it isn't the ring gear...
If you're still reading after that whole mess, I thank and applaud your perseverance in my dilemma.
The other glaring issue is the fact that even when the tractor starts, I have the choice between two speeds of the engine: 1)barely idling or 2)full throttle. The linkage is loose and rubs on the power steering lines which are steel, it's even wearing a gouge into it and I'd like to remedy this because I really don't want to have to replace a hydraulic line. I really detest IH and Farmall's design of their hand throttles, since they run down along the side of the engine, stop at another linkage in the front, and travel up the other side of the engine. Does anyone know how I can adjust this linkage so that I can have full range of my throttle instead of painfully slow and Evel Knievel fast?
After all that, and word on clutch adjustment? Mine doesn't release until about the last inch or so of travel in the pedal.
The carburetor needs to be gone through as well, and I have horrible luck with the tractor not starting after I take apart the carb. Any cleaning or adjustments I can do to help it run more smoothly while it is in one piece?
Thanks so much to anyone who took the time to read this horribly long post, I really do appreciate it. If anyone has any ideas at all, please let me know!
Theo
Power steering
Independent PTO
Live hydraulics
3pt
Torque Amplifier
Theo
