IH 544 Timing
Woodbadge
Good Morning. I have a 1969 Farmall 544 Gas. C200 engine. While timing the thing yesterday, I set base timing at 0 TDC. When I revved it up, the timing RETARDED.
How the heck is that possible? I removed the distributor, tore it apart think something was wrong with the advance weights. The springs may be a little weak,
cleaned and lubed the weights and pivot shaft. Re-installed and re-timed. Same exact thing. From what I know, it's impossible to retard the timing lower than the
Base timing, the timing should only go up. Can the timing pully be installed backwards ? I'm at a loss. Doesn't make any sense. HELP
Hello Woodbadge welcome to YT! You have one of 3 possible things going on with your distributor. One.. the advance weights are assembled wrong and I am not sure if this is possible but may be. Open up the distributor cap and twist the rotor. The rotor should turn against the spring tension clockwise and spring back counter-clockwise. If you are getting a reaction opposite of this your centrifugal advance is assembled incorrect. Essentially if it is possible the weights have to be flipped over to advance it correctly. Two.. the wrong weights have been installed. Three.. somehow a distributor or shaft for an application that uses a counter-clockwise distributor has somehow been installed on your tractor. The only IH applications for these distributors that I know of would not interchange with the parts on your tractor.
Edit: Rereading your post I want to make sure you are interpreting the timing read out correctly. And not to insult your mechanical knowledge sometimes everyone can be confused and not think correctly about technical information. Looking at the front of the engine the front pulley is turning clockwise. Your timing is lined up with a pointer on the engine to line up with a zero or TDC mark on the pulley at idle. When advancing correctly when revved up the TDC mark on the pulley will move counter-clockwise in relation to the stationary zero pointer. Do you agree? In your case you are reporting the pulley mark is moving clockwise from the stationary pointer?
This post was edited by used red MN on 03/11/2022 at 09:43 am.
(quoted from post at 10:19:36 03/11/22) Hello Woodbadge welcome to YT! You have one of 3 possible things going on with your distributor. One.. the advance weights are assembled wrong and I am not sure if this is possible but may be. Open up the distributor cap and twist the rotor. The rotor should turn against the spring tension clockwise and spring back counter-clockwise. If you are getting a reaction opposite of this your centrifugal advance is assembled incorrect. Essentially if it is possible the weights have to be flipped over to advance it correctly. Two.. the wrong weights have been installed. Three.. somehow a distributor or shaft for an application that uses a counter-clockwise distributor has somehow been installed on your tractor. The only IH applications for these distributors that I know of would not interchange with the parts on your tractor.
Good Morning. #1) I don't think the weights can be installed incorrectly, I don't think it's physically possible. #2) After removing the dist cap, I can twist the rotor clock-wise then springs back Counter-clockwise, It only springs back halfway. May need new weight and spring kit. Looking from the front, the engine does turn clockwise, but the distributor turns Counterclockwise. Now, why would the direction of rotation matter as far as the centrifugal force pushing the weights out. If you had a ball on a string, the ball would still react the same no matter which way you spun it.
And when I set the timing to zero at idle, then increase RPM the pulley mark does move clockwise from the stationary pointer. [/list][/quote]
"After removing the dist cap, I can twist the rotor clock-wise then springs back Counter-clockwise"
That is BACKWARDS from how the advance in a distributor that turns CCW should act.
What do you know about the history of your tractor,
how long have you had it? Are there any numbers on
the distributor? I will attach the CNHI parts diagrams
for the C-200 engine in your tractor. They show two
different distributors, in sections G21 and G22 does
yours look like one of them? Both are designed for the
same direction of rotation. You will be the ..Guinea
pig.. trial for first time posting of a link from the
recently updated parts website, hope my link sends
you the right place. You are correct about the
centrifugal weights reacting the same no matter which
way they are spun. However, the direction they turn
the point cam in relation to the direction the distributor
is spinning to make the timing change is different by
..design.. to achieve proper advance in relation to
distributor rotation. Hope you follow, I am saying parts
in your distributor or the whole thing may be meant to
be installed in an engine that has a distributor that
turns the opposite direction then the one for your
tractor does. if you are the original owner and the
distributor has never been changed my ..wrong
distributor.. theory is all wet.
CNHI C 200 parts diagrams
Thanks for the info. The website was spot on. I have the G21 model. Delco Remy 1112697. I've had the tractor for 25 years. It's never been changed as long as I've owned it. Who Knows. Can't say that I remember checking the mechanical advance. I just ordered a spring and weight kit. Maybe that will fix it. I know the springs are pretty stretched. I appreciate the help. Pretty strange for sure. I'll let you know how it works out.
Okay, I made a bad assumption that all IH distributors tuned clockwise, seems that is not correct if you a saying the shaft and rotor in your tractor rotate counter-clockwise, please double check this. In that case as wore out stated for a counter-clockwise rotating distributor the advance should turn ..counter-clockwise against spring pressure and relax back rotating clockwise. In more detail the centrifugal force on the weight should act on the points cam lobe to turn it the direction of the distributor rotation. In detail the distributor fires the coil when the points open. Turning the point cam lobe the same direction as the as the distributor is turning moves the point at which the points open to an earlier position of degrees in relation to the crankshaft, camshaft and pistons. Those earlier degrees translate into an earlier firing of the spark plugs. Firing sooner or earlier, translates to advancing the ignition timing.
I've never worked on that exact distributor. But I have worked on some Delco distributors that look a whole lot like it. On them, you could assemble the weights bottom side up. It turned the centrifugal advance into a centrifugal retard.
So I'm going to say the weights are the wrong side up. Turn them over and try it out.
I know the Magneto's turn backward for gas start diesel engines. Is it possible he has a distributor for a diesel engine?
That wouldn't explain why it has run ok for 25 years though.
Dave
From the descriptions you are providing, if the TDC timing mark moves counter clockwise form the front looking toward the rear of the tractor, that is being advanced. the flash of the timing light shows the pulley earlier (before the mark gets to the pointer as it advances. If it runs, the spark plug wires must be in their correct holes in the cap. if so they will show 1342 going clockwise. Jim
<img src = https://i.imgur.com/GP5Js8f.jpg>
Timing marks and correct advance weight orientation.
In the photo, we are looking at the front engine pulley from the LH side of the tractor, radiator is to the left of pulley, engine to the tight.
If you've had this tractor for 25 years & never
had a problem with it up till now, I'd guess
maybe you never checked the advance with a timing
light before??
If timing gets retarded with an increase in engine
speed, there should be a noticeable laboring of the
engine as speed increases. Is this what is occurring
in your case?
There might be issues regarding front/ back & clockwise/
counterclockwise information furnished.
Could be very cornfusing.
Jim
OK, I finally figured this thing out! After 2 Days. On the 2 photos I posted, notice the 2 holes in the Top picture. If the holes are to the right when you install the weights, the timing backs off when accelerating . And if the holes are left of the centerline the mechanical advance Advances the timing. I thought the tractor ran pretty good all these years. Can't wait to see how much better it runs now. Thank everyone that helped me on this journey. It's the weirdest thing I've ever seen. I sure won't forget this one.
In reply to JAN, the OP in the reply where he answered my questions by numbers the last thing he did say was .. And when I set the timing to zero at idle, then increase RPM the pulley mark does move clockwise from the stationary pointer.. That is not in agreement with how it should react to show advance. However, I am in agreement with Brownie450 this could all just be a matter of confused statements. Even myself I could see that it is possible if he did not just check the timing turn around and type exactly what he saw, relying on your mind to report back later what was seen always being a 100 percent sure is just not humanly possible. I really was disappointed that I first described to him how his distributor advance should react based on a clockwise rotation. I was almost certain all IH stuff used clockwise rotation. I am from the GM camp and I am pretty sure all of their brands used clockwise rotating distributors, so I sort of applied that to all Delco distributors. I guess I just have to admit I made a mistake, which in the end added a lot of confusion to this post ..SORRY.. I confirmed his claim of the counter-clockwise distributor rotation by looking at a set of points for this application. Almost always the points are designed to orientate in relation to rotation in a certain way. Such as a cam lobe first passes the points pivot hinge, then the rub block and last the position of the contact points on the end of the arm. Enough said on that. I agree if the tractor was retarding the ignition timing all these years it would have been a serious dog. If this is actually the case and he gets the advance to work properly he is going to think he has a whole different tractor! There is a possibility that he assembled the distributor advance wrong and so now it is working in reverse, but he claimed this was the reason he took it apart in the first place. I think the the only real way to convey what he sees in the end is for him to take a photo of the advance as it is assembled and also a photo of the timing marks comparable to what woreout posted out of his book and explain by that what he is seeing.
Checking back on some wording in the original post I see the OP added another reply. It looks like he determined the advance could be assembled in two ways as Jim Becker suggested. I suspect ..and nothing against the new poster, everyone has there moments.. he simply assembled the advance opposite of how it was originally. He said himself he was convinced it could only be put together one way. I hope for his sake it has been wrong, as said above he will have a whole new tractor.
Woodbadge, I see you made a reference about photos you posted. You likely could not post a photo here until you have a post count of 5. I do not see them, your post count is now 5 try posting the pictures again they will probably come through. You need to use the ..Choose files.. button at the bottom of the ..Reply.. page to choose them out of your storage. Off topic I am not sure how many on here know a Woodbadge is a Boy Scout leader achievement award, my son is an Eagle Scout and my father-in-law has multiple Woodbadge achievements.
It still won't let me post photos.
Thanks used red MN. I originally check timing and then noticed the mechanical advance was backwards. That's what started this mess. THEN, I removed the distributor. You're correct, it wouldn't let me upload the photos. you can see the 2 holes are off center. If you turn that base plate one way the timing will retard. If you turn it 180, it will advance. It had to been that way for years. I don't remember ever checking the timing at idle for 0 degrees. I'd just ran the idle up and set it at 20 BTDC. That's probably why it seemed to run fine. Again, Thanks to all for all the help.
By the way, you are correct about being a BSA scoutmaster(10years worth) I am a Woodbadger, a BobWhite!! Congratulations to your son and Father-in- Law as well. My son is also Eagle.
