Good Morning. I have a 1969 Farmall 544 Gas. C200 engine. While timing the thing yesterday, I set base timing at 0 TDC. When I revved it up, the timing RETARDED.
How the heck is that possible? I removed the distributor, tore it apart think something was wrong with the advance weights. The springs may be a little weak,
cleaned and lubed the weights and pivot shaft. Re-installed and re-timed. Same exact thing. From what I know, it's impossible to retard the timing lower than the
Base timing, the timing should only go up. Can the timing pully be installed backwards ? I'm at a loss. Doesn't make any sense. HELP
